It is currently Mon Jul 21, 2025 10:20 am
PostPosted: Tue Dec 20, 2005 6:06 am
I'm a beginner, so please excuse my ignorance. I'm afraid I may ask question sometime that gets those to scratch their head and ask themselves, "Is this guy serious?" Hopefully this is not one.
Oh, I should state that I'm doing a nylon string (Flamenco.) Seems like most here build steel strings.
I want to use a non-traditional wood for my fingerboard and bindings. It is very dense, second only to Lignum Vitae, and filled with a lot of resin - Venezuelan Verawood. I talked to Marc at Gilmer wood and he thinks that it would sound terrible.
My question is, how much affect can a fingerboard have on tone? Bindings I can see having some affect, and bridge certainly, but a fingerboard?
Given that this is going to be my second guitar, this probably doesn't matter. There will be more factors for me to be concerned with than the affect of a wood on my guitar. But I'd still like to know.
PostPosted: Tue Dec 20, 2005 6:46 am
Hi B
I only build Steel Strings, but I have heard it presented that the denser the fingerboard material the greater the resonance, from my own experience I would say that I can see the theory that the less give in the material the string is being anchored against whilst being fretted, the less string energy that is lost by absorption. I am sure there is something in this and the fingerboard material probably does have an influence, I would say the effect is probably quite small. I don't know if any of the more scientific guys have done any testing around this, my position is based on gut feel rather than hard evidence.
I would say go for it that way you will know wether it works for you, and who knows you might hit onto something really good, and I would say there is no chance its effect would be so dramatic it would destroy the tone of an otherwise perfect instrument.
PostPosted: Tue Dec 20, 2005 7:50 am
Neck vibration can extract a little energy from the string, so a heavy or stiff neck might give you a little more sound than a lighter/'floppier' one. It's a little hard to say.
One thing that can effect the tone is the frequency of the 'neck' vibration, which is really a vibration of the whole guitar in which the neck bends a lot. If that 'neck mode' pitch matches the 'main air' resonance pitch the two will work together to move more air through the soundhole over a braoder frequency range. The tone of the lower notes can become particularly 'dark' and 'rich'.
To check the 'neck mode' frequency, hold the guitar up by pinching the neck right around the nut or first fret, so that the guitar hangs freely. Don't pinch too hard! Tap on the back surface of the headstock up at the upper ed, or else tap on the heel. Listen to the sound that comes off the headstock, and move your holding point around a little to get it to be as clear as possible. On many guitars it will be well below the pitch of the low E string, and thus won't effect the tone, but, if the neck is stiff enough, and the headstock and machines are not too heavy, it might be as high as F or G on the low E string.
The easy way to find the 'main air resonance' pitch is to lay the guitar down on it's back on a padded table top or in your lap. Pinch the low E string fairly tightly between your thumb and forefinger with the left hand, and pluck it with your right. Slide the pinch point up and down, listening for how loud the sound is. It will be muted, because of the damping of the flesh of your fingers. The loudest sound is the center of the 'main air' resonance, and will usually be near G on the low E string, although it can range a bit.
The frequency match between the 'neck' and 'air' modes has to be pretty exact to get the effect. Small changes in the stiffness of the neck, and the mass of the headstock, can change the 'neck mode' pitch and switch the effect on and off, which is why little things like swapping machines can make a big difference in the tone sometimes.
A carbon fiber rod will do a lot to stiffen up the neck. Tapering the neck, so that it's thicker by a few mm at the body end, also helps a lot.
PostPosted: Tue Dec 20, 2005 9:30 am
I was just reading "Luthier's Handbook" by Siminoff and he says about what Alan said. More mass in the neck and headstock = more sustain. He also says on page 34 that a zero neck angle is ideal for an acoustic guitar. Hmmmmm.
PostPosted: Tue Dec 20, 2005 10:09 am
Siminoff seems to have a pretty decent selection of slightly odd ideas.
